D15b7 To D16Y8 Swap Eg civic
xmod
Im currently underway in swapping out my blown d15b7 motor to a d16y8 into a 93 eg civic hatchback. Has anyone done this swap before as im not sure with the engine mounts in regards to the left top mount near the power steering pump and also the rear mount bracket do i need to swap these both over to the d15 stuff or is there a way to make it work becuase i have tried to install the motor but it just wont line up
Any help will be greatly appreciated
take the one by the power steering off of the d15 and bolt it on the y8. im pretty sure you use the stock one (from the d15) on the rear too
