d15b7 tranny question
Discussion in 'Civic and del Sol - EG and EK' started by jaylo, Jan 15, 2007.
  1. jaylo
    jaylo New Member
    will a transmission from a d16z6 work with a d15b7 engine for a 92 civic dx hatchback.
  2. bitchasscracker
    bitchasscracker Banned
    sioux city iowa
    yes it sure will and has a shit load better gears too
  3. jaylo
    jaylo New Member
    will I have to change anything out beside the tranny such as pressure plates or flywheels or will it bolt right up.
  4. bitchasscracker
    sioux city iowa
  5. JDMGen2
    JDMGen2 Junior Member
    Any D Series trans will bolt to any D series block. Same with B series. H and F are also interchangable.
  6. bitchasscracker
    sioux city iowa
    not true
  7. turbo sol
    turbo sol I need some ligaments!!!
    laurel, montucky (ten minutes out of billings)
    yes it is if you're talking JDM to JDM but it is true that some won't bolt up if they are USDM and JDM ...they won't mix.
  8. bitchasscracker
    sioux city iowa
    you are so dumb
    ok a 91 prelude motor (b20) and a 91 integra tranny (B18A) ????
  9. turbo sol
    i'm not too savvy on b series shit, i'm a d series guy...
  10. bitchasscracker
    sioux city iowa
    then what is the spool time on a sc61 57 trim on a d16
  11. turbo sol
    4200 at the most.. that turbo isn't that big..
  12. bitchasscracker
    sioux city iowa
    your a retard i told you in the other post i have the set up its 6000-6200
  13. turbo sol
    what you say is not golden kid...it's ok to be wrong sometimes...
  14. bitchasscracker
    sioux city iowa
    SC-6152E look at the specs yourself retard
    i guess your right a turbo with a hp rating of 630 hp is small
  15. turbo sol
    i didn't say it was small, i said it's not that big, which it isn't..
  16. bitchasscracker
    sioux city iowa
    your just a retard
  17. turbo sol
    ok....i'm a retard...happy?
  18. bitchasscracker
    sioux city iowa
