Hey guys had a quick question, I have a ej2 and was wondering what head and ecu I should I put. Also what other parts are needed. I read that the CR nd everything are the same except the redline. Any answers?
I've seen many people due a d15b7 to d15B... the head swap is a must, wire up vtec, get a p28 or p08 ether should work and also wire up the oil presure switch.. d15b is a simple motor
You would need it so the ECU would know there was enough oil preusre to run vtec. After you swap the heads I did a write up on the D15B http://hondaswap.com/civic-del-sol-eg-ek/d15b-write-up-251182/ Hope it helps, tells u what pin outs to use for the VTEC A6 on a p28 or p08 and D6 for oil pressure
