d15z/to d15b
Discussion in 'HYBRID -> EG-EK / DC' started by oxxie, Jan 19, 2008.
  1. oxxie
    oxxie New Member
    Can anybody help have eg d15z v/tec E motor was cooked not noing a lot put jdm d15b v/tec in using original harness 5 wire o2 sensor changed p07 to p28 not sure whether it came out man or auto mine is man . engine light comes on around town not on trips question knowing not the right 02 sensor what sensor should i use and can i fit it to original hareness
  2. 93civicracer
    93civicracer Oh, I do a little here and there.
    Texas
    I'd get a factory service manual, figure out what each of the o2 wires are, then cut and splice the 4 wires from the o2 sensor to the harness that match up and leave out the extra.
    Edit: Or wait a minute. Figure them out, then just cut off the extra and leave the plug on LOL.
  3. haao13
    haao13 New Member
    PA
    i really couldnt even understand that. you should try using some punctuation so people will be able to understand wat your problem is
  4. 93civicracer
    Texas
    His problem is 5-wire to 4-wire o2.
  5. oxxie
    oxxie New Member
    "Sorry, not so good on the keyboard, problem is - wiring harness is suited for 5wire O2 sensor. But now using a P28 cpu, not sure what O2 sensor suits P28?" Does it need a 4 wire, and can I fit it to existing wiring harness?" thanks for the reply.
