youll need motor mounts, upgrade to a dual core radiator prob from a 99 or 00 civic si, wire the knock sensor, depending on where you get the motor youll need shift linkage and axles but some places give you that with the new motor. of corse your gonna need a b series tranny either a s21 or a y21 but i would go for the y21 because of the gearing and limited slip. b series radiator hoses and a new throttle body cuz you have no place for the map sensor on your new motor. but once you get all the parts this is a very very easy swap depending on you mechanical knowlage you should be able to knock it out in a weekend. i actually swaped the same motor into my vx about a month ago you should be very pleased with the power you can get out of 1.6l
