d15z1 to d16z6 o2question
cgeg5hb90
Ok I know u have to use the vx harness. Btw I have eg 4 vx hb. But since I'm using the harness why can't u just use the 5 wire o2 instead of rewiring for the 4 wire. Is it cause the p28 ecu only reads a 4 wire or what? The reAson I'm asking is cause my d16z6 is cracked . I just got it:( itw not even in my car. But I have a after market one to replace it but I have tried fukin everything to get the damn o2sensor out!!!
yes the 4 wire will read for a p28 and its a different ecu engine and all. so it needs the 4 wire. but any d series header will fit from 88-00 and there cheap so just get a new one
I got a header. Just seeing if I have to go buy a new o2 sensor since I marred up my other one so bad.
