D16 Intake Manifold swap question
Discussion in 'Civic and del Sol - EG and EK' started by B.lane89, Apr 28, 2008.
  1. B.lane89
    B.lane89 New Member
    I have a pretty much stock d16z6 in my del sol and I would like to change the stock Intake Manifold for a skunk2 Manifold and go with a 68mm or 70mm throttle body and cold air intake. I was wondering what I would need to do to correct the air fuel mixture after adding so much air into the motor.
  2. B.lane89
    B.lane89 New Member
    well I plan on eventually turbo charging the engine and this was one of the cheaper things i wanted to do for starters. I guess I would be better off just buying a hondata ecu because it will be needed in for the turbo anyway and then just get the intake with the stock throttle body right?
  3. eg6sir
    no need for Hondata.. use Chrome, its free.. just have to buy a chipping kit
  4. B.lane89
    B.lane89 New Member
    thank you guys for the help and Blanco thanks for the interest in everyone's post. Every thread I have read you have straightened everyone out at least once
