D16 OBD1 SWAP to b16a2 obd2 Questions
Discussion in 'ECU's, Electronics, and Tuning' started by Delsol94, Mar 6, 2009.
  1. Delsol94
    Delsol94 New Member
    Boonsboro Maryland
    i was told that i can use my d series wiring harness....is this true? it seems way too easy to just bolt in and connect everything?
  2. GLV08
    GLV08 New Member
    Denver
    From what i've read and heard, you almost always have to swap a few connectors, lenghten some wires here and there, and change the ecu. Also if the motor is obd2 and the harness is obd1 i believe that you have to adjust some of the sensors such as the o2. I could be wrong on this but at least its a start =D
