d16 pistons
Discussion in 'General Tech and Maintenance' started by nismogod, Apr 2, 2004.
  1. nismogod
    nismogod Senior Member
    Deltona, FL
    can anyone tell me the total height from center of rod bolt, to the highest point on top of the piston? i'd appreciate it much, also, if someone could tell me the outter diameter of a b16 rod bolt. thanks!
  2. phunky.buddha
    Dallas / Fort Worth, TX
    I don't know the numbers off the top of my head, but you can find them almost anywhere. Search for "compression height" for your wrist pin to piston deck measurement (won't give you the top of the dome height) and look for "wrist pin diameter" for your rod bolt. I assume those are the measurements you want. If so, the wrist pin diameter should be 21mm.
