D16 swap question
Discussion in 'Civic and del Sol - EG and EK' started by lilredcivicpgh, Sep 23, 2007.
  1. lilredcivicpgh
    lilredcivicpgh New Member
    Pittsburgh, PA
    Yea I want to swap my D16Z6 with a D16Y8 does anyone know where i can find detailed instruction on doing that.
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    its easy. just swap them same mounts and all and will wire right up, all you have to do is convert it to obd2
  3. lilredcivicpgh
    Pittsburgh, PA
    so i just need an obd2 and it's a plug and go?
  4. AHHVTEC
    Alabama
    yea just buy a jumper harness and off you go..
  5. lilredcivicpgh
    Pittsburgh, PA
    thanks i'm headin to look at one in a lil bit
  6. lilredcivicpgh
    Pittsburgh, PA
    if i do the swap can i keep my trans and half shafts?
  7. lilredcivicpgh
    Pittsburgh, PA
    also can i just swap my dist. on the y8 from the z6
  8. lilredcivicpgh
    Pittsburgh, PA
    would my distributer work from a z6 work on a y8?
  9. AHHVTEC
    Alabama
    yes you can just keep your stock tranny and axles it will all bolt right up
  10. lilredcivicpgh
    Pittsburgh, PA
    but can i keep my distributer? or do i need to get and OBD2 and a jumper cable.
  11. AHHVTEC
    Alabama
    you need the jumper there like 70 bucks at rywire mabe more but not much
  12. lilredcivicpgh
    Pittsburgh, PA
    wat about the ecu or do i need the OBD2 one?
  13. AHHVTEC
    Alabama
    you need the ecu that will run that motor so if the motor came out of lets say a 98 modle buy a 98 modle ecu thats vtec the ex modle.so yea you need a obd2 ecu
  14. EGProject
    EGProject YEEEEAAHHHHH
    Whitinsville, Massachusetts
    I believe you can run re-pinned OBD2 dizzy with an OBD1 car, and not have to convert the whole thing over. Most of the sensors are the same, but the IM may require some plug swapping.
  15. AHHVTEC
    Alabama
    this is true also, i was giving the least of a headace way
  16. lilredcivicpgh
    Pittsburgh, PA
  17. crxguy88
    crxguy88 New Member
    can you use the obd1 civic cx on the d16y8 head? that's what i heard..anyone wanna back that up and tell me..
