d16 y8 can i stick it in a 90 honda
Discussion in 'Civic and CRX - EF' started by hydrocivic, Dec 7, 2009.
  1. hydrocivic
    hydrocivic New Member
    i have a d16y8 and i have a 90 honda civic dx hatchback with a 1.5 i would like to know can i take the 1.5 out and swap it with the d16y8 if i can what will it take to do it
  2. phunky.buddha
    Dallas / Fort Worth, TX
    1. Welcome to Hondaswap
    2. Stop posting in weird fonts and colors- it's hard to read
    3. Yes you can. You have a DX, so you need to perform a DPFI to MPFI swap (search for it on the site), add VTEC, then decide how you want to take care of engine management- run the non-OBD MPFI electronics (your year) with the VTEC added on somehow, or convert to OBD1 or OBD2 and run newer hardware. All versions have been done many times.
  3. hydrocivic
    from what year civic should i get the hardware from
  4. riceracerex
    riceracerex D-Series Ninja
    Pryor, Ok
    1990 I would think?
  5. lucky09
    lucky09 New Member
    u would need to buy new mount for it also
  6. hydrocivic
    but i think that the d16y8 is not 90 think its 96
  7. eg'sforlife
    eg'sforlife New Member
    29 stumps, CA
    its still a d series motor if your worried about the year then get a z6
  8. m90polk
    m90polk Member
    ri
    like they said above it will fit ur stock motor is a d series, u can run the stock tranny which is a cable transmission with the y8 or u can run the transmission that came with it but it hydraulic and you will have to hook up the hydraulic setup. The dpfi wiring to mpfi is real easy and the vtec wiring isn't hard either...as far doing the swap just search through HS it is full of information, there are a lot of good write ups on here, read them and don't be afraid to ask questions that u have.
  9. hydrocivic
    whats a z6 and how i get it
  10. phunky.buddha
    D16Z6 from 92-95i Civic EX and Si
    junkyard, store...
  11. hydrocivic
    well just came across a honda accord with a v tech in it what can i do to it just to let it be known i love speed so what can i do to it
  12. ZCpowerdSI
    ZCpowerdSI New Member
    ON, Canada
    Its vtec not vtech. there is no "h".
  13. D16SiHatch
    D16SiHatch New Member
    wow.. are you 14?
    "with a v vtech in it"? seriously? It's vtec not vtech, vtak, vtek, or any other variation. the engine itself utilizes vtec ok. so saying it has a vtec, without including engine, motor, or warp drive afterwards, just sounds ridiculous.
    yes you can install a y8 engine in your car, and you can also install a honda accord f-series engine in your car if you so choose. the y8 is going to be easier however.
  14. hydrocivic
    k vtec what can i do to the vtec to make it go in the civic or the accord i just want to make it scream
  15. hydrocivic
    well i was wonderin if the vtec would bolt up to my 5 speed tranny in my 90 civic
  16. riceracerex
    Pryor, Ok
    ...I think you need to read a little more about d-series hondas before you do major work on one. Vtec stands for Variable Valve Timing and Lift Electronic Control. A d16z6 is an engine found in 1992-1995 Honda Civic Si's or Ex's and can bolt up to your transmission but Hydro's are nice to have. You can check out Rywire.com and find conversion kits to make the wiring easier also.
  17. hydrocivic
    ok so ya and thanks for the sight
  18. DAallday
    DAallday New Member
    Look at this site. It'll probably help you if you know how to read :) I think your best bet is to get a jdm obd0 b16a if you want "v tech". But considering you don't sound to bright, i'd suggest you stick with the d series. By the way, period's and comma's would make it alot easier for us to read what you're trying to say.
  19. riceracerex
    Pryor, Ok
    We got the gist of it and we are here to help.
    You can also spend hours of time searching for knowledge to be obtained from this forum.
    :search:
  20. hydrocivic
    hey im just wonderin if it would or not thats it i can take care of every thing else i just need to know if i need a diffrent tanny or not k
