d16 y8 can i stick it in a 90 honda
Not to hijack this thread, but I am putting a y8 into a 90 but an std. I have a 5spd tranny (cable) from a friend, axles, knuckles, etc. so that is all good. I need to know what ecu to use and I am planning on a boomslang harness for the ecu. I figure I can use the clutch & pressure plate from the 90 on the y8 engine. I'm planning on using the harness from the d15 and maybe using some sensors if I have to. I have an ecu from a 94 gsr but I don't know if that will work. Any help?
a si harness and a pm6 is what I am using. A p28 would be the best ecu I think but someone else will be able to answer this question much better than I. You can chip certain ecu's to run different engines also.
