D16A swap into EG possible?
SLOWdelawareEG
my cars go fast
basically a USDM version of the ZC motor it is a 1.6 DOHC. comes from old 'tegs. what mounts to use? which trans to use? will distributor from stock motor fit (since both motors are D-series)?
6-8 will be fine on that motor. you can expect somewhere around 160 whp or so.. probably a lil less. Depending on what you use, and how well it is tuned. But yes, 6-8 psi will be safe. As far as worth it, well i'm not so sure about that.
