d16a1 help
Discussion in 'General Tech and Maintenance' started by doeboy208, Nov 23, 2008.
  1. doeboy208
    doeboy208 New Member
    i have a 92 honda civic, i have gotten told that it wont work the fact that the mounts are in different locations.
    can some one help me, show me a thread to go to.
    something that will help or should i just sale the motor and trans.
  2. austin20110
    austin20110 New Member
    Northern Va
    your wanting to do a swap? you want to swap another d in? WHY
  3. doeboy208
    well i traded my audio equipment for the d16a1 and i got told that you cant swap it and i am wondering if your really can.
  4. austin20110
    Northern Va
    yea you can but i cant understand why you would want to
  5. doeboy208
    but not the trans can you?
  6. austin20110
    Northern Va
    yes the trans will bolt right up.... a d-series is a d-series
  7. doeboy208
    yeah but the d16a1 is for the acura and a crx si.... thats what i have been told...
  8. austin20110
    Northern Va
    D16A1 1986-1987 Integra
    you might need new mounts..
    what are your goals with the car
  9. efhondakid
    Akron-Canton, Ohio
    NO it didnt come in a CRX, the D16A1 came in the first gen Integras. It will swap into you car, but why are you wanting to do this swap?
  10. doeboy208
    well i am running a d15b7 right now and the d16a1 is a 1.6 and mine i have now is 1.5 so not much diff..
    goals turbo, something qwick but not too fast
  11. doeboy208
    really not wanting to do swap after reading that its not much better than what i have.. but if i did it, it will be for exp thats it
  12. austin20110
    Northern Va
    ok so why did you get that motor
  13. doeboy208
    well the kid i got it from said it was a zc so i believed him but then when he left and i warmed up i checked the ser. and its not
  14. austin20110
    Northern Va
    i would have kept that to myself lol
  15. efhondakid
    Akron-Canton, Ohio
    You have a lot to learn, you can tell the difference between an A1 and a Z6 blinfolded. If I were you I would sell it and boost your motor if you want to go faster.
    1 person likes this.
  16. doeboy208
    like i said in my first forum i really dont know much bout import
  17. austin20110
    Northern Va
    welll anything you need to know make sure you search you can find just about anything you need to know there alone.
    :search:
  18. doeboy208
  19. austin20110
    Northern Va
    but let me tell you a few things....
    its a honda, its fwd, dont get a wing
    a body kit isnt going to make you faster, nor will stickers
    you dont need 8 cyl. to go fast
    o and if you feel like a speed demon keep it on the track
  20. D15Beater
    D15Beater HNFTuning
    Concord N.C.
    Ok yes it will work, best swap? No, but thats not for any of us to decide for you. Use your sohc drivers side mount, and your sohc transmission, all the bolts to bolt it to the engine will match up but one, you dont need this. If you feel better it can be drilled and tapped for a bolt. Its been done though numerous times without issue. Using your sohc transmssion will allow you to use your mounts, drivers side will fit the D16a1, you may have to remove the cover to expose the holes, you may have to cut it out, i dont know , never done the swap but have seen it successfully done. Youll will also use your sohc wiring harness on the DOHC. Should be the same as swapping a ZC, or another sohc, all but that one bolt that wont line up. Be sure you use clutch kit that matches your transmission.
    It wont be the fastest thing, but you can swap some 1st gen ZC cams in to it for more power.
