D16A1 uses a 200mm diameter clutch - the D15B7 uses a 212mm diameter clutch - the D16A1 clutch pressure plate will not bolt onto a D15B7 flywheel - you cannot use the D16A1 flywheel with a 88 and up transmission - the D16A1 didn't use a pilot bearing in the flywheel which is needed to support the transmission input shaftwill the d16a1 clutch work for my d15b7?
