d16a1 into a 89 crx
Discussion in 'HYBRID -> ED-EF / DA' started by chondacrx, Jul 18, 2004.
  1. chondacrx
    chondacrx Junior Member
    what all do i need to put a d16a1 integra motor into a 89 honda crx
    thanks
  2. ExplicitSnow
    ExplicitSnow Senior Member
    youll need:
    motor
    tranny <--crx si tranny will work
    harness <--crx si harness will work
    shift linkage <--crx si linkage should work
    mounts <--stock mounts work, no modification
    ive got a 90 crx si w/ a dohc zc...swap was easy and fast...cheap too
    My CRX w/ DOHC ZC
  3. defensio
    defensio Junior Member
  4. 91crx
    91crx Senior Member
    dont do it just use the sohc zc motor because it will be cheaper to do and it will have more horsepower a d16a1 motor only has 113 horse
  5. stichedskater
    stichedskater Junior Member
    will work but need mount on driver side also integ harness and ecu it would be ok to get mount of old integra but have to weld it on its not a zc right and distributor
