I have a 93 civic DX and will a 89 integra dohc head work with my sohc block and stock ecu? Does it make a difference on performance?
Just get a mini me head from a 92-95 ex or si. sure you only keep one cam but the vtec makes a bigger difference and you will get more power, besides a total swap should cost at most $300.
hi, i own a rover 416i with a d16a3 motor. i just took the old motor out and put an 86 in, and there is an outlet on the gear box side, under the head which has no pipe going to it?? what is it for as water is coming out of it as i fill the radiator?
