d16a6 block d16y8 head help
Discussion in 'Civic and CRX - EF' started by juju-ed7, Apr 10, 2015.
  1. juju-ed7
    juju-ed7 New Member
    Hi
    I have a 1990 Honda civic Si hatch I'm trying to do a mini me swap. I have the head however I don't know what headstuds to use or main studs to use. Do I use the y8 or a6 studs??
  2. jlicrx
    jlicrx Senior Member
    Colorado Springs
    use the Y8 for the head - mains are the same A6 or Y8
    juju-ed7 likes this.
  3. juju-ed7
    juju-ed7 New Member
    Thanks a lot man but I can use ARP y8 headstuds or doesn't matter
  4. jlicrx
    Colorado Springs
    you can use ARP Y8 head studs - Y8 and A6 head bolts/studs are different lengths
  5. whiterabbit06
    Crestview, Fl
    If you use a y8/y7 head with a pre-1996 SOHC block you need to use 9 88-95 SOHC head studs and 1 96-00 head stud. Basically 9 long ones and 1 short one for the hole near the distributor on the intake side.
  6. whiterabbit06
    Crestview, Fl
    If you take your head off and have the 10 stock bolts that are all the same length then screw them all the way down in the block you'll see one will be sitting higher that the others, that's where the short stud will go.
