D16a6 build????
Discussion in 'Engine Building' started by goldHB94, Nov 8, 2007.
  1. goldHB94
    goldHB94 New Member
    i have a stock A6 motor that is in need of a rebuild and i have a stock dx EF hatch that i need a motor put in to drive daily and i also have a turbo set up for a sohc so i want to put it all together and make a good daily with a lil more pep in it step!
    this is how far i have got
    i got a whole gasket kit, new .20 over pictions cuz the cylinders were pretty rusty, i got new rings and befor the motor goes to the motor builder are there any budget tricks to do to a A6 to make a lil more power? rember i want to drive it daily threw the winter.
    also will a stock clutch hold up on such motor with 7psi?
    i have built a few hondas but this is my fist sohc build and all my other builds have been forged and more power goals.
  2. dacheat
    dacheat ..is grounded.
    strongbadia
    subscribing..
  3. norcalgsr
    NorCal
    If you are going to run a turbo I would suggest ARP rod bolts and head studs since the engine will already be apart. Chances are the stock clutch will not live very long on 7 PSI I would probably upgrade that as well to at least an Exedy stage 1 or equivalent. I can't think of any low budget tricks off the top of my head, but with 7 PSI and good tuning you should be able to extract enough power to make you happy IMO.
  4. goldHB94
    goldHB94 New Member
    i thought i read some where there were head and cam swap that would make a lil power
  5. goldHB94
    goldHB94 New Member
    no vtec i have a z6 head but dont want that i was wondering if there is a stock cam out of a different motor that will fit and make bump hp's a bit (ect y7 b7 b1 ...)
  6. goldHB94
    goldHB94 New Member
  7. goldHB94
    goldHB94 New Member
    i am looking now
  8. goldHB94
    goldHB94 New Member
  9. donny_ptrsn
    donny_ptrsn New Member
    Tucson, AZ
    i know that zex makes a cam and so does skunk 2 so yeah i think i would get a clutch from act or something the make some good quality shiittt..
  10. goldHB94
    goldHB94 New Member
    ya i ordered a act clutch for it last night
  11. hatukazi
    hatukazi ambitious...but rubbish
    Big Lake, MN
    a mild port and polish definately wouldn't hurt, maybe a 3 or 5 angle valve job and back cut valves...
  12. goldHB94
    goldHB94 New Member
    hummmm
