D16A6 - D16Y8 Mini Me Swap
Discussion in 'HYBRID -> ED-EF / DA' started by Projekt Koncept, Jul 26, 2004.
  1. Projekt Koncept
    Projekt Koncept Junior Member
    My friend owns a 1990 Honda CRX Si, and wants to do a Mini Me Head Swap. He's looking to swap out the A6 head with a Y8, as it offers higher compression than a Z6. My question is, where can he find a complete head other than a junkyard? I've been searching google to no success. And ebay doesn't look to promising. Also, is there anything besides the head he would need? Any suggestions and help would be appreciated.
  2. dreded90crxsi
    dreded90crxsi Senior Member
    About the only place you'll find a y8 head is through a junk yard, ebay, or people selling them through internet forums. I would try checking every honda related forum you can find and look in their for sale sections. Things you will need besides the head is wiring up vtec and finding a way to activate it. The best way to do it is to convert from obd0 to obd1 and run a p28 ecu. It will give you better fuel maps and has vtec activation already in it. Another good idea is to get the y8 intake manifold. It flows air much better then the a6. Oh yeah when converting to obd1 you will have to change the fuel injectors and distributor.
  3. MugenCRX
    MugenCRX Senior Member
    Thornton CO
    :withstupid: You will also need a new headgasket, I would recommend ARP headstuds if your friend plans on doing anything in the forced induction department and look into converting to OBD1. It will save your friend some headaches.
  4. Projekt Koncept
    Thanx guys, that answered the most important question, on where to get a Y8 Head. After Swaping the head, I'm assuming he'll get some aftermarket Cams and then a Turbo. So with all of this in mind, what is needed to convert from OBD0 to OBD1? And do you have any other suggestions?
  5. dreded90crxsi
    To convert from obd0 to obd1 you can either buy a conversion harness from hasport or you can do the wiring yourself. If you do a search on google for obd0 to obd1 conversion you should be able to find plenty of sites that will tell you step by step how to do it.
  6. Projekt Koncept
  7. dreded90crxsi
  8. Projekt Koncept
    So far this is the list of things my friend will need for the Mini Me swap. Hopefully I haven't missed anything.
    OBD0 - OBD1 Wiring Harness
    p28 ECU
    Fuel Injectors
    Distributor
    Headgasket
    And of course, the Y8 Hhead.
    About the ECU, would this be aquired from Hondata, or is it a stock ECU from a newer model? Sorry if this sounds n00bish, but this is somewhat of a learning curve for us. :sad: But we are learning! ;) Much thanx again!
  9. dreded90crxsi
    The p28 is a stock ecu from 92-95 civic ex and si.
  10. 89' Project Civic
    89' Project Civic d16a6/d16y8 "mini-me"
    St. Catharines, Ontario, Canada
    Sorry to open up an old thread guys, but I'm doing a mini-me swap (d16a6 bottom end, d16y8 top end) as well and was just wondering when you said about doing a obd0 - obd1 conversion, wouldnt it be either a obd0 - obd2a or 2b?. I have a p28 ecu for my mini-me swap. I'm just a noob as well and dont know much and am rather confused so I'm not challenging anyone I just need to know what to do, thanks guys!!. As well, I have the y8 head COMPLETELY apart and it's going for a hot-tanking soon, Im looking to maybe go Stage 2 or 3, which companies should I use and would this be a bad idea??.
  11. D15Beater
    D15Beater HNFTuning
    Concord N.C.
    You could just run a pw0 or pr3 on that. Theyre both obd0 and you would only have to run the vtec wires and knock if you went with the PW0. Its a dohc ecu but the y8 head will put you around the same C/R as the B16. Use a y8 head gasket, if you shave the head i wouldnt go over 0.010 of a inch. that would put you around the 10.5:1 ratio.
  12. 89' Project Civic
    I already bought the p28 for $40 on eBay.ca. So, what your kind of saying is that if I just do a fresh stock rebuild and shave the head by 0.010 of a inch I will get 10.5:1 cr?. I am kind of confused if I'm staying with a d-series so I don't know if it's worth building the engine really hardcore, do you think sticking with a stage 3 d16y8 would be worth the money and time or will I just build this mini me stock then want a b16a2?. Also, I don't NEED to go with a obd2 setup? Thanks alot for the reply!!.
  13. wes lee
    wes lee SOHC Fury
    texas
    i thought all we had to do was run a P28 and convert to OBD1 (even though the Y8 is OBD2) i know that OBD1 is able to convert to OBD2 so there shouldnt be an issue
  14. c-rex-beat
    c-rex-beat yeah, it's a vtec.
    tyler, TX
    on my swap I used a p28, jumper harness, use a6 fuel rail and injector and intake manifold just to maki it easy. if you use the y8 injector you will also need to change the conetors on harness and the fi box in the corner for it to work and get the same result. use gasket for y8 and get arp head studs for the a6 block. once you raise the compression you will not be able to boost with out blowin the f up. I do have a y8 head minus the vtec solenoid, fresh cam and valves, powder coat cover (orange). pm me if interested.
  15. wes lee
    wes lee SOHC Fury
    texas
    God i can't wait to blow mine the fuck up!!!
  16. wes lee
    wes lee SOHC Fury
    texas
    thanks for that info!!! saved my ass ^_^
  17. 89' Project Civic
    He's 100% right, how's the swap coming along wes lee?
  18. Reboticon
    Reboticon New Member
    Knoxville
    You can't hot tank aluminum.
  19. 89' Project Civic
  20. 89' Project Civic
    I know you can't, but who said that?
