D16A6 engine harness to dx
Discussion in 'Civic and CRX - EW' started by d16a6civichatch, Nov 3, 2008.
  1. d16a6civichatch
    d16a6civichatch New Member
    i need to know what to do to the engine harness to fit the stock plugs?????
  2. jlicrx
    jlicrx Senior Member
    Colorado Springs
    the D16A6 MPFI engine harness will not plug into the DX chassis harness - to swap the MPFI engine into the DPFI car, you use the engine harness from the DPFI engine and make the necessary changes to convert it to MPFI - you can use the injector portion of the MPFI engine harness and the MPFI distributor connector when making the conversion - you will need to run additional wires from the ECU to the engine for the 2 added injectors and the cylinder sensor in the distributor - the DX chassis harness does not have wiring from the ECU to the engine for these items
    this is a good link for making the DPFI to MPFI conversion:
    FourthGenHatch
