D16a6 HELP will not run
well if your gettin spark and you have fuel to the fuel rail then theres really no reason why it shudnt start but the only thing is prob the fuel pump and you should have a place behind the front seats in the middle of the car to get to it and take a tester to the clip and see if its gettin power before you drop the tank to put a new pump in and if its gettin power then it has to be the pump or the main relay cuz that went for mine one time i was driving fine i drove to work and lunch but after lunch i went to go start it to have the mechanic check the timing and it wouldnt start and it was the relay so check that too
random stalls...fuel pressure sometimes? def check that pump
no i got it fixed finally a coupple weeks ago....now it runs like a champ....just drove to seattle and back. Now i have to sell a coupple heads.....i need cash
