D16A6 into 6th Gen? Crank Sensor A Problem??
Discussion in 'HYBRID -> EG-EK / DC' started by rfrumusa01, Aug 9, 2010.
  1. rfrumusa01
    rfrumusa01 Bean Cakes
    Rochester, NY
    So I have a D16A6 short block that I was hoping to toss into my EK for a daily driver, but I'm concerned about the crank sensor. Is this swap even possible? Where does the crank sensor mount and can I transfer it to the A6?
  2. tabKola
    tabKola New Member
    Tewksbury MA
    It mounts on the Y5/7/8 oil pump, so you would have to swap over the pump, but then you would have 2 dipstick holes.
  3. d-mon
    d-mon what r u compensating 4?
    just get an obd2/1 conversion harness and a p06 ecu.
    keep your y8 intake and exhaust manifolds.
  4. D16SiHatch
    D16SiHatch New Member
  5. suspendedHatch
    suspendedHatch audio/security
    Search for FFsquad and how to do the CKF bypass trick.
