D16A6 into 90 civic hatch STD wont start
your wiring is wrong.
check the dizzy wiring that is running into the passanger side ecu.
its either you have it flipped or wired wrong.
most people encounter this problem. I did everytime.
I can check it again, but I should be seeing a ecu code if the wiring is wrong, and Ive checked a few times, Im going to test compression right now.
Alright, I tested compresion, its reading 90 psi at Idle warm, which is wrong, there is no way this engine would run this well with that compresion, its not burning any oil, and there is no coolant oil mix, Im going to bring home my bosses snapon compresion and leakdown testers on tuesday and see if I cant get a more accurate reading, now Im off to Grand Rapids.
Happy Newyears all.
