d16a6 swapped into a 1990 civic HB DX?
Discussion in 'HYBRID -> ED-EF / DA' started by lonelydriver, Aug 23, 2004.
  1. lonelydriver
    lonelydriver Member
    will the d16a6(crx si) engine and tranny directly fit into the 1990 civic HB DX?
    thanks in advance.
  2. exospeed*com
    exospeed*com Member
    The engine and tranny will fit right in no problem. its the wiring that will need some work to conver to a mpfi from the dual point FI of the DX
  3. lonelydriver
    lonelydriver Member
    alright, thanks a lot. just wanted to make sure i didn't need new mounts or axles, etc.
  4. dragon2003
    dragon2003 Senior Member
    northern, cali
    you will need the si axles also, cause the dx axles have different splines. and you will also need an si ecu to work with the MPFI, cause you will no longer have the dx DPFI.
