D16A6 to D16Z6 in '88 CRX Si
Discussion in 'Civic and CRX - EF' started by thehoochabides, Apr 22, 2009.
  1. thehoochabides
    thehoochabides New Member
    northern california
    im sure this swap has been covered on here a million times, but im having somewhat of an emergency and need answers relatively quickyly. my '88 CRX Si blew up and i found a D16Z6 that i want to put in. i need a list of parts to buy and other suggestions or common mistakes that get made doing this swap. will my tranny hook up? basically an overview of this swap would save my life. thanks a lot
  2. efhondakid
    Akron-Canton, Ohio
    I takes 2 seconds to search and you will get all your answers.
  3. sevenhillsbilly
    sevenhillsbilly New Member
    obd1 jumper harness, p28 ecu, driver side mount off of your a6 if im not mistaken and yes your tranny will bolt up as long as you use the fly wheel for that transmission.
