D16A6 with a T3/T4 57 trim, dizzy issues
Discussion in 'Forced Induction' started by danse, Oct 17, 2006.
  1. danse
    danse Junior Member
    Has anyone had an issue of blowing alot of oil out of the dizzy? I always seem to have some oil under the dizzy prior to the turbo but now it blows out. I replaced the "O" ring on the shaft but no luck. I don't seem to have any shaft play but there is oil inside. I don't want to replace it being that I have B16 that I will be installing in a few weeks so I don't want to spend any more money. Am I missing anything that someone has seen before? Thanks...
  2. gettocrx
    gettocrx Member
    Honolulu, HI
    I seen that before. Its probably the shaft so you'll need a new one. But since you're doin the swap soon, just run it like that unless its real bad
