d16a6
Discussion in 'General Tech and Maintenance' started by '91rex, Jan 27, 2007.
  1. '91rex
    '91rex New Member
    d16a6 'check engine light'
    I'm having problems in high rpms, i think wen i took it to get a oil change those dumb fucks @ sears wore my elec. tape on my intake tube an thats where it started. anyway i took it to auto zone, they cant check my ecu for error codes cuz its not a late model. its sort of a puttering, feels like its bout die. wen i nail it---nothing---but as soon as i come off jus a little...puh,puh, puh,put. and it jerks a lil. heeeeeeelp!:(
  2. '91rex
    '91rex New Member
    does anyone know any possible error codes that i'm experiencing?
  3. Reckone
    Reckone EF aholic
    Albany, NY
    By your SN I take it you have a 91 CRX? If so pull up the carpet on the passanger side under the dash. You will find the ECU there. Theres a red LED that will flash if you have a check engine light on. Count how many times it flashs. You will have to pick up a manual or search online for the diagram to tell what the Check engine light is on for.
  4. 801CRX
    801CRX Got Rice?
    UTAH
    Hell yeah the reference section in some manuals are useless.
    Hondaswap reference for the win!!!
  5. '91rex
    '91rex New Member
    checked it out, the light only came on once wen i was driving it. then it went off. i guess the ecu didnt store the eec. however the dam motor is hesitating wen i'm jus chillin over 60mph, or better yet, @ high rpms. I, as well as my mechanic is stumped!
  6. 801CRX
    801CRX Got Rice?
    UTAH
    Spark?
    Cap, rotor, wires, plugs and dizzy.
    Valve lash?
  7. 801CRX
    801CRX Got Rice?
    UTAH
    My 89' HF did the same thing and it turned out to be the valve lash!
    Oh yeah by the way thanks to Blanco for that one.
  8. '91rex
    '91rex New Member
    nothing really, jus checking for the ecu flashes--none. but i'll see, in a day or so. what is 'valve lash'?
  9. '91rex
    '91rex New Member
    i also thought about when i 1st bought the car. when i noticed smoke over 60mph, i found that all the valves burnt up except one. so i think i'll replace those too, it's been about 18,--- some odd miles since they were replaced / and high temps due to constant radiator leaks. on a tight budget, any good suppliers you know of?
  10. '91rex
    '91rex New Member
    btw, i'm not too ecstatic about that ebay crap they're selling
  11. '91rex
    '91rex New Member
    the fucker died on me....r.i.p. 2/17/07........havent found out what's wrong with it yet....
  12. 90 si crx
    90 si crx New Member
    swaping out a d16a6 with a d15b2
    90 crx is what is needed
