erebunicrx my name is Dale Jul 19, 2004 #1 just wanted to know what is need to put the motor into a 91 si hb. also would i gain anything from puting this head on a d16a6 block?
R racintweek Senior Member Jul 19, 2004 #2 D16A8/9 is the European equivalent of a ZC everything bolts up you need to swap your engine mounts to that motor and bolt it in i think a few wires need to be extended dont bother with the teggy engine just get the d16a8/9 i believe the teg engine has lower comp and weak cams
