D16A8 into a 91 DX Hatch
Discussion in 'HYBRID -> ED-EF / DA' started by supersol93, Oct 13, 2003.
  1. supersol93
    supersol93 Member
    Southeastern, PA
    I have a D16A8 and a 91 DX hatch. I am planning on rewiring the whole car as it is completely stripped right now. I am going to use a 90-91 interior harness, but what engine harness will I need to make this work. If I use the Integra engine harness will it plug into the interior harness. Please help
  2. supersol93
    supersol93 Member
    Southeastern, PA
    Any help would be appreciated
  3. brian11to1
    brian11to1 Senior Member
    give better specs of the engine dude what car did it come from.. Im lost are you talking 86-89 Teg... cuase if not then where did the Teg wire harness come from? and if hte wire harness is from a 90-93 Teg it's for a b series and wont work on a D' I dont think... shit you got me man, lata'
  4. supersol93
    supersol93 Member
    Southeastern, PA
    A D16A8 should tell you all you need to know. Its from an 88-89 Integra. I know the D16A1 (86-87 integra) wont work because it has a vacuum advance dist. whereas the 88-89 has an electronic advance. So the engine is from an 88-89 Integra and thats where the Integra engine wiring harness came from
  5. supersol93
    supersol93 Member
    Southeastern, PA
    I'm assuming that nobody knows?
  6. supersol93
    supersol93 Member
    Southeastern, PA
  7. 91dxSiR
    91dxSiR Member
    change from dpfi to mpfi...all u need to do,..wiring wise....as for making that motor fit... have fun
  8. supersol93
    supersol93 Member
    Southeastern, PA
