D16y7 Cam
MoparMick
What would be a good cam to go with a d16 wich will soon be turboed?
Why are you getting a cam for the y7 when you are turboing it?
Just spend the dough on a good turbo and crank the boost.
is the bottom end built because i know that you can boost a good bit if you have a nicely built bottom end without the cam
the bottom end was rebuilt back to stock about 35k ago. the head i found out already has a cam that im not sure of. but how many lbs would i be able to push vary safly with a block guard.... i dont want to blow anything up
Pressure all depends on the tune and the turbo choice. A few people have gone as high as 400whp on the stock block casting without guards or new sleeves. That's not typical though.
and when im looking at turbos and it says operating psi what dose that me... for example... t3t4 said 25- 40 psi.
