ttboostboy
i need help my motor cranks and starts but boggs out and dies after 10 seconds or so. I have fuel and spark. I am thinking this is due to my MAP sensor because i spliced the plug from the main harness as i have a DX chassis and engine wiring harness. There are 3 wires a pink wire a yellow/green wire and a solid green wire. I need to know the order of these wires on the plug as i am using an EK plug with different colors. This is off the DX models with the MAP sensor located on the firewall. also is there a reliable obd2-obd1 distributor wiring conversion writeup. It seems that there are different ones all over the forums.
