d16y7 in obd1 del sol timing off but runs fine
tempsho85
hello everyone.. i just got another honda recently and i am in quite a situation. my car is a 1995 del sol s currently their is a d16y7 engine in it running on a obd1 po6 ecu..the problem is that the timing is off at least ten degrees...the car runs but when i max out the distributor the timing is still off about 10 to 15 degrees to where it should be on the crank pulley..the y7 ccrank pulley is installed and i tripled checked the timng belt but that is on corectly ..i am running out of ideas...could the problem be the wrong distributor?
