wildcat820
The rpm switch idea works but there is no saftey net with that setup ie. no low oil pressure vtec cutoff+ d16y oil pump= grenade. I'm not trying to flame your setup though. i would just recommend something a little more cookie cutter for this particular setup.
NO Flame Taken! I guess I should ADD the fact that I port the shit outta the stock oil pump! and I Make a sweet Epoxy radius on the plugged end of the Pump. Then I take the Pressure regulator plunger out and stack a couple Brass washers from the hardware store as a pump shim! Walla 85 pounds of pressure at mid throttle and 50 at idle! AND I BEAT THE HOLY BALLS OUTTA THE THING!!!!!
