D16y7 to d16z6 using stock engine wiring harness
Discussion in 'HYBRID -> EG-EK / DC' started by bruce974, Jun 27, 2012.
  1. bruce974
    bruce974 New Member
    Hi, all
    I swapped my d16y7 out of my 98 civic non-vtec. i swapped a d16z6 vtec engine and i still only have the d16y7 harness and P28 ecu with a harness converter.
    I added some wires for the vtec pressure switch and vtec solenoid.
    the engine starts normally but when I start to accelerate,
    the engine is not performing too, the others symtomps are:
    It's very hard to start the car, engine will stumble upon acceleration too and I have a CEL code 9( crank angle sensor fault).
    I use all d16z6 sensors ( dizzy, injectors, throttle body, IACV...)
    can you help me please?
  2. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    Replace the sensor. It's down by the crank. Or.....maybe it's a bad connection/not plugged in properly.
  3. bruce974
    bruce974 New Member
    In D16Z6, I think crank angle sensor is integrated in the dizzy.
    I have already tested another dizzy and the problem persists :(
