d16y8 block need help
boxinggsxr
what block is almost same or if not better for stock d16y8.. my cuz spun a rod or bearing and is looking to try and swap block but will he need all new rods and pistons or what?
Don't understand that but you can get an a6 block with like 100xxx km on them. And iv seen them last till 450-600xxx km.
Just rebuild it if your worried about the miles..
The y7 block is exactly the same as the y8 block. (you just have to tap for knock sensor if you want it)
I just sold a y7 block in perfect working condition with 120xxx on it for $125
You can get y7's for like $100 on craigslist. and that's with the head and everything
why the hell would you go back to a single cam when you could swap anything into that engine bay unless you like having a car thats not even fast enough for grandma to drive.........
thats not always true. a honda motor is what you make it.
