chasesk20eg
I just put a D16y8 from a 97 civic ex in my hatch. It runs great but when the oil level is full it smokes real bad. If the oil level is about half it only smokes when vtec kicks in.
mine did the saeme thing and the valve seals were bad. only smoke when the v-tech engaged. all i can advise is do a compression test and if that all looks good then you are more then likely looking at bad valve seals. good luck
