D16y8 Head On My D15b7 Del Sol S, Possible?
Discussion in 'HYBRID -> EG-EK / DC' started by vpSPOONsol, Apr 1, 2003.
  1. vpSPOONsol
    vpSPOONsol Senior Member
    mildenhall village, england
    I recently got a d16y8 head to do a mini-me swap on my d15b7 del sol. im wondering if i shoulda got the d16z6 head instead? which one is an easier swap? which one will give me more power? also, would i have to change to an obd 2 if i use the y8?
  2. saturn_boy96
    saturn_boy96 88 C1V1C 53D4N DR1V3R
    Sheridan, WY
    should have got the z6 head, switching to obd2 will be a pain.
  3. Roro
    Roro Member
    Z6 head.
    I have a spare w/o valve cover/dizzy/vtec solenoid. But it has the intake mani if you want to name a price. Only 50k on it, came out of a wrecked EX. :sleep:
  4. vpSPOONsol
    thanks, but what would it take for me to run an obd2? cant i just use the 96 ex ecu?
  5. Roro
    Roro Member
    the OBD2 motor...why oh why would you want to run it?
  6. teal_dx
    teal_dx Member
    Medina / Akron , Ohio
    No, Keep the Y8 Head, they are wrong- Y8 Head will give you more power (raise compression) AND you can use your OBD1.
    I did the same swap in my civic, here is my photo ablum:
    http://www.imagestation.com/album/?id=4290602507
    The Y8 may be a little more work, but worth it! :worthy:
  7. teal_dx
    teal_dx Member
    oops! forgot to mention in the photos to use your stock D15b7 Distributor. Y8 Dist has different harness= extra step to hardwire!
    good luck! :)
  8. Roro
    Roro Member
    BARELY any more power, just because the quench areas are larger or something. Not enough to bother with the y8 head and having the extra headache.
  9. vpSPOONsol
    thanks teal, i'll stick with the y8 head....
  10. aux
    aux New Member
    heres a dseries engine build calculator.
    http://www.knology.net/~jediklc/D.htm
    with only a y8 head + y8 headgasket i got a compression of 11.04 using the d15b7 complete block. i wonder how THAT would do with an oil cooler system and better water cooling system for the engine, + i/h/e + tuning and a 7500 rpm redline and 9 tops. i wonder how long the d15b7 block would last in this build.. switiching to obd2 ? doesnt that involve just switching the injectors if your going to run an external vtec conroller and use the stock ecu? i wonder how poerful this would be, sure would run hot. they already run hot as hell. i just found out that a jdm d15 vtec block doesnt have oil squirters. i thought they did, and the z6 block had them as well. now im thinking if im going to go with this build after i do the a6 cam, its prolly more practical to just stick with the b7 blocks and have a few prebuilt. ive hear you have to use special plug wires, which doesnt make any sense...correct me if im wrong here.. only looking for 150-ish HP and around 120-ish TQ
  11. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
  12. aux
    aux New Member
    yeah i know, thats ok with me.
  13. aux
    aux New Member
    5 years and still ppl are doing mini me's
  14. AHHVTEC
    Alabama
    yeah lets lock this one up guys
  15. DerronG3
    DerronG3 New Member
    haha... another 3 years later and here i am wondering pretty much the same things this guy was for my exact same swap
