D16Y8 Head Swap to ZC?
Discussion in 'Engine Building' started by SQ Civic, Aug 20, 2006.
  1. SQ Civic
    SQ Civic New Member
    A buddy of mine said that I can put a DOHC ZC head on my D16Y8 block.
    Anyone done this before? Can it be done or is he just a retard?
  2. phunky.buddha
    Dallas / Fort Worth, TX
    Retard
  3. jlicrx
    jlicrx Senior Member
    Colorado Springs
    why not just get a DOHC ZC engine? - if you were to put a DOHC ZC head on a D16Y8 without changing pistons, you would end up with compression ratio of 7.95:1 which is not much good for anything - DOHC ZC heads have been swapped onto SOHC D-series blocks, but not without a lot of machining - a ton of work to get the same thing as you would (provided you changed pistons) if you just used a DOHC ZC
    Putting a zc dohc head on an A6 block. - TheZCR.com Forums
