d16y8 in a 92 civic
Discussion in 'HYBRID -> EG-EK / DC' started by nappyrat, Dec 22, 2006.
  1. nappyrat
    nappyrat New Member
    so basically i have an obd2 d16y8 that i want to drop into my obd1 civic, what is the easiest way to tackle this? i do have tha engine harness and ecu for the d16y8, should i convert my car into obd2? or keep it 1?
    ive been told i can transfer over my CX obd1 dizzy/alternator/and engine harness and just get a p28 and run the vtec wires and be done with it, but it seems alot harder than to just convert it to obd2, bc from what i heard everything will wire up right from the engine-harness-ecu, but i'll have to fix some wiring to the electrical harness behind the firewall. has anyone done this or anyone who knows whats best give me some input? thanks!
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    use your stock harness convert it to obd2 and just run the wires for vtec
  3. nappyrat
    nappyrat New Member
    why do i use my stock harness? to run obd2 i already have the harness and ecu for the y8.. im confused
  4. AHHVTEC
    Alabama
    it will just be easer that way
  5. nappyrat
    nappyrat New Member
    can you elaborate on it though? how would i go about converting it to obd2?
  6. AHHVTEC
    Alabama
    just buy the jumper harness and plug it up
  7. nappyrat
    nappyrat New Member
    anyone have any other suggestions?
  8. Ress887
    Ress887 New Member
    When you swap motors into different cars, its a cardinal rule to use the harness that came with the chassis of the car.
    Use your VX engine harness and buy an ECU Jumper Harness from a website like JDMshit - Performance Parts & Accessories Supplier or a Rywire harness. If its a 96-98 y8 be sure to get an OBD2a Jumper, and if its 99-00 get a OBD2b Jumper. Cost around 75.00 I think.
    If your distributor is vtec, use it or use another OBD1 vtec distributor, and wire in vtec to your harness. You can find information about doing this on alot of websites, try Honda-Tech.com: Main Forum List .
    Then sell me your d16y8 harness if it's for a manual transmission because I need to replace mine in my 97 EX. :D.
    Any other questions PM me and I can most likely have a thoughrough answer for you.
    -Matt
