trevorsevoviii
ok so i need a reliable daily driver so i was thinking about swapping the newer civic motor(d16y8) so i can get a lower milage engine, my question is will this motor bolt up to the d16z6 transmission? Also i know ill need the 0bd2 to 0bd1 wiring harness for the ecu, but when you use the harness do you keep the ecu that went with the d16z6 and attatch the harness to that ecu? And also is there anything else ill need to do for the swap? i really need to know this stuff asap so i can get the car on the road, im out of a car right now. Thank for all the help guys-travis
