Sensors yes. As for the throttle body you can if you are keeping the engine as a Y7, but there is a small hole on the throttle body opening on the Y8 manifold that will have to be covered. The hole is obvious if you compare the Y7 opening to the Y8.
y8 manifolds are confusing there are 2 versions auto and manual and the iacv ports are not machined on a auto intake and it also has the 3 wire iacv on it.
