D16y8 Intake Manifold
Discussion in 'Engine Building' started by CRX_Si, Jun 5, 2003.
  1. CRX_Si
    CRX_Si Senior Member
    Lynchburg VA
    is the d16y8 intake manifold plug and play on a d16a6 head? and is a b18b throttle body plug and play on the manifold and on my car (91 crx si)? thanks
  2. red95solsi
    red95solsi Senior Member
    Kansas City Missouri
    it will all bolt up but you have to lengthen wires for a sensor to go elsewhere and the hole is not the same size as the throttle body will the throttle body bolt up yes but take smething to make the hole bigger so you get the gain of the bigger tb other the just partial throttle
  3. CRX_Si
    Lynchburg VA
    so you are saying that it will bolt on but there is one sensor that needs to have it's wires lengthened? and if i use the ls TB i shouldnt have to bore the IM any right? and what about the vaccum hoses? everything in the same place? thanks
