D16Y8 Into EG Hatch Shell.
Discussion in 'Civic and del Sol - EG and EK' started by LilCarolina, Feb 12, 2013.
  1. LilCarolina
    LilCarolina New Member
    Need some help. Just picked up a 93 Civic VX Hatch shell. Going simple and dropping in a D16Y8 motor. Problem is the car has no engine or cabin/dash harness or ecu. Can't really complain since it was free. Question to you all is which ecu do I get and which doner car can I pull the harnesses from? Thanks
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    well if the car has zero harnesses then just get everything from a 96-00 civic ex
  3. 99sidude
    Ohio
    The EG civics have a two piece engine/cabin harness, while the EK's have a one piece. To avoid a lot of confusion, just get the EG harness. You can either run an obd1 p28 ecu, or run the correct obd2 ecu for that engine with a jumper harness.
  4. civicious
    civicious FüK-VTEC VIP
    Houston, TX
    This, exactly.
    /thread
  5. josh_crewdson@y
    josh_crewdson@y New Member
    nova
    It's not that easy, the obd2 ecu's look for more than the obd1's.
    Fuel tank pressure and something else.
    I tried it one time in an obd1 car, I could never get rid of all the codes, it always ran rich and shitty.
    I was out $135 in the end and ended up running it on a p28.
    Ran better with the p28 than the p2p w/cel's.
  6. AHHVTEC
    Alabama
    is the car not a hull ? i was thinking if it is then shouldn't it be easy just to add all the stuff from the origin of the motor and be done with it.
  7. 99sidude
    Ohio
    Even if it is just a hull, the engine/cabin harness will need to hook up to the EK insturment harness and the floor harness. I hightly doubt this will work. I am intrigued now, so I will try to check tomorrow.
  8. civicious
    Houston, TX
    Incorrect. Re-check your facts.
