D16y8 Swap In 88 Crx Dx
Discussion in 'HYBRID -> EG-EK / DC' started by fwddrag, Feb 28, 2003.
  1. fwddrag
    fwddrag Junior Member
    can someone helpme maybe a step by step and parts i need. please help.
  2. D16z6CrxDx
    D16z6CrxDx Senior Member
    you need to use your old tranny and wireing and injector resis. box u also need to use a 88-91 SI or HF dist. another thing you need from your old motor is the driver side mount that bolts up the the motor u need to take the old one off and put the origional mount on the y8 motor u also need a 88-91 SI ecu or the first gen interga ecu but its must be a 5spd if ur set up is 5spd as for vtec u need to wire it up which ever way u want vtec controller, switch or using a pr3 or pw0 ecu....
