D16Y8 Throttle Body ???Quick Question???
Vanard
99 Civic D16Y8,
On The Lower Back Side Of The Throttle Body There Is Place For A Hose.
After Replacing My Engine I Have A Small Coolant Hose Coming From The Pipe That Runs Across The Back Of The Block Connecting The Water Pump & The Thermostat.
It Just So Happens That The Small Hose Fits On The Place For A Hose On The Throttle Body.
So, Does The Throttle Body Have Coolant Running Through It?
Not In The Intake Area, But Like A Water Jacket OR Is It A Vacuum Line???
Thank You In Advance For Any & All Assistance Regarding This Matter...
Yes it should have a coolant line running from the back to the front, this helps keep the throttle body cool I do believe..
