D16Y8 - which ECU ?
Discussion in 'ECU's, Electronics, and Tuning' started by sula, Aug 14, 2005.
  1. sula
    sula Junior Member
    Hello,
    recently I've made swap from D14xx to D16Y8. Currently inside is P45 Accord's ECU (dont ask !) which I'm planning to replace. Now my doubt is which ECU should I get ?
    P28 or P30 ? Which is better for me ? Why ?
    Thanx...
  2. VTECPOWER
    VTECPOWER Senior Member
    Winchester, VA
    P28 = obd1 sohc vtec ecu aka d16z6
    P30 = DOHC VTEC b16 ecu also obd1
  3. sula
    sula Junior Member
    yes I've read that here on hondaswap...
    but I want to know if I put P30 which is DOHC on SOHC motor, is there any benfit from that action...?
    dont know maybe rich fuel mixture or so ?
    maybe is p30 like slightly chipped p28 ? :)
  4. VTECPOWER
    Winchester, VA
    :no:
    Just get a p28 if u want to do obd1
  5. sk8er602
    sk8er602 Senior Member
    Athens, Ga
  6. sk8er602
    Athens, Ga
  7. Taco15
    Tallahassee Fl
    p28.
    Question, can you put a p28 ecu on an lsvtec to covert to obd1 or do i have to installl p30? the current ecu is a pw0. SORRY TO THREAD JACK
  8. pissedoffsol
    you CAN put just about any ecu on any motor. Will it run good is a different story.
    for the OP, just run the p28 if you're obd1 chassis. the p30 maps aren't remotely close for running a y8.
    Other than the obvious different fuel, igntion, vtec, and redline, the only difference between the p28 and the p30 is that the p30 has a knock sensor circuitry.
    other than that, they are pretty much the same thing... (usdm vs usdm of course)
  9. 98civic4door
    98civic4door Junior Member
    I have a P28 forsale pm me
