ok yea its there, but its black, but i think thats, correct me if im wrong, because its obd2
I don't get it. So you have a D16A6 botton end and which top end do you have?does anyone have VTEC schematics?. Also, on a d16y8 can I use the p28 and get a jumper harness then wire VTEC?. I have a d16a6 bottom end.
start your on thread but search firstI asked if I could use a p28 on a D16Y8 head, I have a d16y8 head.
Converting your car over to OBDII which the Y8 is is too hard. If you could rig up a Z6 dizzy on the Y8 head that could work after converting it to OBD1. The Z6 dizzy doesn't line up with the Y8 head. The P28 world run the Y8 head with a Z6 dizzy.I asked if I could use a p28 on a D16Y8 head, I have a d16y8 head.
Is your car DPFI or MPFI?Hey man, I appreciate your understanding, being a noob sucks. What your saying is that I can use my p28 (obd1) ecu and get a obd0 to obd1 jumper harness will work with a d16z6 dizzy? (with modification). What head gasket should I use??. Y8 Headgasket and t.belt?. Thanks a tonne for the help, man.
