Here is the story Recently ,I swapped d16z5 (DOHC) (D16A9 in US) engine from 91 crx into EK(don`t ask me whay) instead of d16y7 that was completely destroyed.I have chanched the distributor and injectors to obd2 ,and done the wiring.The only thing I did not changed is the ecu,simply becouse I had only obd0 ecu from crx,and I didn`t think it is a greate idea to make it works with obd2 electronics. My question is :what ecu I can use with this particular combo? Thanks Alex P.S. Now I have that 3-wire IACV problem.
Hi, im trying to put a D16Z5 into a EJ6. I would like to ask some questions. My ICQ is 162-048-988. Hope to hear from you soon
