D16Z6 1/4 times
Discussion in 'HYBRID -> EG-EK / DC' started by RFHOMI2U, Dec 17, 2002.
Thread Status:
Not open for further replies.
  1. RFHOMI2U
    RFHOMI2U Senior Member
    Just bought a SOHC VTEC D16Z6 for my '90 CRX Si, just curious how the quarter mile times will be. Even stock times in a 92-95 Civic Si/EX would be helpful. Just curious how fast it will be when it is in. Thanks for your input....
    -kid with the Z6 in a REX
  2. chet
    chet Senior Member
    st petersburg, florida
    a kid i know went 13.7 with his d16z in an 88hf.
    now this is a worked motor, in a lighter car, but i'll say you'll run 14.9's.
  3. 84' lude dude
    84' lude dude Junior Member
    I don't believe these numbers, My lude ran 17.1 at 87 mph and it's fully built.
    I/H/E, no cat,full plugwires(msd 10.4mm),splitfire plugs,air filter removed,msd ignition, fully gutted, ac/power steering removed.
    turbo kit's on the way :eek:
  4. chet
    chet Senior Member
    preludes are heavy and in most cases slow because of their weight.
    go to the track more often and watch d16z crx's.
    i've seen one on the spray (50-shot) go 12.54.
    stock d16z, no LSD.
  5. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    wow.. that must suck to have all that money into it and still run a 17.1
  6. Y8 CRX
    Y8 CRX Junior Member
    17.1 is all you ran....i know people w. newer pludes runnin 14's with just IHE....you sure you can drive it?
  7. knowledge
    knowledge Senior Member
    Beale AFB, CA
    lmao. Yeah alot has to do with driver skills. Try doing a search on google for "D16Z6 crx". You should be able to find a bunch of crap.
  8. joeNOKO
    joeNOKO New Member
    15.1 with stock intake and exhaust.. that was in an ef si hatch.. i jst got exhaust and ima get a vcon tomarrow then ima take it to the track and see if i can get a 15.0
  9. eg6sir
    wow.. you revived a 7 yr old thread..
Thread Status:
